Squeaking front end
Old Apr 6, 2016 | 01:54 PM
Maczter's Avatar
Maczter
Default Squeaking front end
Has anyone had any issues with squeaks in their front ends? I have an '08 Laramie 4wd, with 98K. Have had a very irritating squeak coming from the front end. Happens most when colder, and no logic to how. Just backing out of the driveway it squeaks, going down the road it squeaks, and turning it squeaks. Just replaced the struts and shocks so not there. No clunks or shimmy either. Is this a common problem? Since it is all sealed, there is nothing to grease.
Old Apr 6, 2016 | 03:02 PM
Ball joints squeak when they are out of grease.
Old Apr 6, 2016 | 09:01 PM
cruzer55's Avatar
cruzer55
WD40, shoot it between the bushing and metal,soak it good.should get rid of the squeeks.
Old Apr 6, 2016 | 11:39 PM
Maczter's Avatar
Maczter
Ball joints are sealed, will give the WD40 a shot, can't hurt! Thanks.
Old Apr 7, 2016 | 12:35 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
If the ball joints are original, I'd bet real money that's the culprit. They are sealed, as you said, so they are unserviceable. Replace with MOOG or something else that is greaseable.
Old Apr 7, 2016 | 07:38 AM
Yes. Sealed and probably out of grease. WD40 is a bandaid.
