a/c problem
Old May 30, 2016 | 11:06 PM
ram/hemi's Avatar
ram/hemi
Default a/c problem
I have a 2004 Ram hemi and the problem is that in traffic the other day, the a/c started blowing warm air. When I started to drive at a steady speed the air got cold again. When I stopped it got warm again. Anyone have that problem before and what could be he cause?
Old May 30, 2016 | 11:58 PM
66three83's Avatar
66three83
Condenser fan is not working.
mrmike525xc's Avatar
mrmike525xc
Check condenser fan motor operation. Sounds like condenser fan not coming on.
Had to replace motor on my 06. A little difficult without discharging a/c, and having hoses connected.
Old May 31, 2016 | 08:55 AM
HemiLonestar's Avatar
HemiLonestar
Yep, this just happened to me, have to replace the fan.
Old Jun 1, 2016 | 10:48 AM
ram/hemi's Avatar
ram/hemi
Thank you for the responses. I was afraid of that, just needed to confirm.
Old Jun 1, 2016 | 11:32 PM
66three83's Avatar
66three83
Why afraid of that? That's a 10 minute job. Could have been your compressor that failed!
Old Jun 17, 2016 | 03:12 PM
c0le's Avatar
c0le
I'm having this exact same issue on my 2006 Ram 1500 Lone Star edition. From other threads on these forums I've read and from a little googling, it seems to confirm this you can hit the fan with a small hammer or screw driver and if it starts spinning, it's definitely the fan. I also read on older models it could be a condenser fan fuse #39 if it doesn't spin at all or some kind of a relay. Does the 2006 model have this fuse/relay? It can't be #39 because that's the Sunroof/Seatbelt Tensioner fuse.
If it does infact end up being the condenser fan, can someone confirm this is what I would need?
http://shop.advanceautoparts.com/p/d...1&prefZC=75228
And video for DIY:
Thanks for the help!
Old Jun 20, 2016 | 09:58 AM
HemiLonestar
Did you just vent the refrigerant lol? Mine absolutely cannot be removed without detaching the condenser itself.
Old Jun 20, 2016 | 12:06 PM
66three83's Avatar
66three83
It looked easy!!! After looking it up, yes, you have to remove the condenser. Seemed to me the fan would be attached in some other way. Another great design Fail !!!!
Old Jun 21, 2016 | 09:15 AM
mrmike525xc
It is possible with out discharging a/c. But not easy. Remove top core support to be able to move things around. With support removed, I was able to unbolt shroud from condenser and wiggle my arm up in between and get motor out.
I am a 30 year retired, factory trained Chrysler tech. Experience does help.
I didn't take pics though.
I recently had to do right exhaust manifold bolts too.
Good luck.
So I watched the video. I don't like cutting structural items. I was able to do in the truck.
DO NOT HIT CONDENSER WITH WRENCH, OTHERWISE YOU WILL BE DOING CONDENSER TOO!
