Passenger side window stopped working?
Old Jun 10, 2016 | 07:14 AM
Mikedip7's Avatar
Mikedip7
Default Passenger side window stopped working?
Long time troll, first time poster. I've found a few similar issues by searching but nothing that close
Just yesterday, I went to roll down my passenger side front window. And it decided to just stop working. I didn't notice any issues with the window prior, it was going up and down at a normal speed
Now, the driverside switch . . Does absolutely nothing. The window will not open or close.
However, the passenger side switch will allow the window to go down. But not back up.
Anyone have an suggestions on where to start looking? I'm assuming it's either gonna be: the master switch, passenger side switch, the actuator, the motor took a sh**, or the wires?
Old Jun 10, 2016 | 08:26 AM
Sounds like good places to start. If the window works normally from the passenger switch then you can safely assume it's not the motor or the passenger switch. Focus on the driver switch. Possible the contacts are corroded.
Old Jun 10, 2016 | 03:28 PM
p38251's Avatar
p38251
Sounds like a bad master switch.
Old Jun 12, 2016 | 02:33 AM
BigHorn70's Avatar
BigHorn70
Got the same issue with passenger side. Running in random. Will follow this thread.
Old Jun 12, 2016 | 10:03 AM
phillip123hastings's Avatar
phillip123hastings
That's my thought as well.
Old Jun 14, 2016 | 03:04 AM
Friar Tuck's Avatar
Friar Tuck
Which truck is this? Need to know so I can find the wiring diagrams.
Old Jun 14, 2016 | 03:42 AM
Friar Tuck's Avatar
Friar Tuck
I'm gonna guess broken ORANGE/GRAY WIRE from driver door to front passenger door.
Old Jun 15, 2016 | 07:58 PM
skiahh's Avatar
skiahh
Interesting... mine has sort of the opposite problem. Passenger side switch is intermittent, but the driver's side is fully functional. And my passenger heated mirror doesn't work.
I haven't opened up the passenger door yet to check connections, nor have I pulled the passenger door switch module. It's all about the time!
Old Jun 17, 2016 | 01:13 AM
Friar Tuck's Avatar
Friar Tuck
SKIAHH: looks like your '03 heated mirror problem is gonna be in that passenger door like you say. Everything else is in common with the left side.
The heater element is on pins 11 and 13 of connector 302 in the side panel in front of the door, or pins 1 and 5 on the mirror.
