I think I blew my ac compressor
Old Jun 12, 2016 | 05:10 PM
blackdodge_man's Avatar
blackdodge_man
Default I think I blew my ac compressor
So I went to put some Freon in my truck it sucked up two cans quickly so I went and got the third. About half way threw the 3rd can the system blew out Freon when the fan kicked on so i know i already over pressurized the system. started looking online and from my reading it says once the valve releases the freon it will force you to get a new compressor. I also touched the ac line and it almost burning hot. So if I did do this how munch is this gonna cost me? I got a 2006 dodge ram 1500, $150,000 miles.
Old Jun 12, 2016 | 07:24 PM
p38251's Avatar
p38251
If you have it done 1200 ish. New compressor, receiver dry. Recharge. And labor. Bout half if you do it yourself. Buy gauges.
Old Jun 12, 2016 | 09:08 PM
blackdodge_man
Well from what I have read and from listing to the truck it sounds like I just over charged the system. The fan still kicks on. So would the repair shop just drain it and fill it back up? Or if i was to let it set a few days and not run the AC would it go back to normal pressure and run fine?
Old Jun 12, 2016 | 10:06 PM
Jmn822000's Avatar
Jmn822000
If you buy the parts and install them yourself you can get away with maybe $500.
Compressor $275 - Denso
Drier/accumulator $40
Orifice tube/liquid line $40
Expansion valve if applicable
Flush and PAG oil $30
Which ever line broke $
Some parts houses sell kits that include the top five parts and include a 2-year warranty.
Old Jun 13, 2016 | 12:56 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
No, the popoff valve will reseat itself just like any other relief valve. Get your ac serviced by someone with an actual machine to do it right. $149.95 is about the going rate some places are cheaper.
Old Jun 13, 2016 | 02:29 PM
superdak05's Avatar
superdak05
if you need to add the Freon, then doesn't that mean there is a leak somewhere in the system? I would first have a leak test done to see what needs to be replaced, then go from there.
Old Jun 13, 2016 | 10:49 PM
blackdodge_man
Went to have it looked at and saw that the condenser fan is going bad. It will turn on but only after you hit it with a pair of pliers or your hand. Now the person who looked at it called in for the part and told me that he could not get the fan by its self just the whole thing which I found odd. So I got online and found just the fan for $65. Also been watching youtube videos on it. Does not seem to hard to fix. Plus he quoted me about $280 for getting it replaced while another place would charge $380. Is that reasonable or very high to you guys?
Old Jun 13, 2016 | 11:21 PM
TNtech's Avatar
TNtech
The AC has to be discharged and the fan removed WITH the condenser, then separated by bolts. It's kind of a stupid setup, but at least you know your Freon level will be right when it's done. Get the fan assembly instead of just the motor or you'll probably be doing again in a year.
Old Jun 13, 2016 | 11:26 PM
blackdodge_man
You dont have to discharge the system or remove the condenser just watched a video on it.
Old Jun 13, 2016 | 11:30 PM
TNtech's Avatar
TNtech
Sorry, I'm speaking from my world of an equipped service dept where it takes half the time to do it by discharging it.
