3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Im getting misfire and injector codes on cylindar 2 4 6 8. Passenger bank i swapped coils from one side to the other the problem stay on passenger side. Not sure where else to go heard alot about faulty ecm and possible a fuel pump any help is appreciated.
The fuel pump is not smart enough to produce mis-fires on one bank. Does it run rough? How does it idle?
I went and bought a used ecu today with matching numbers and when i asked the dealer to reflash they told me they couldnt and the only way to replace ecu is to buy new and have them flash.
Do some troubleshooting before throwing parts. How's the fuel pressure between to two bank. Compression check. Any vacuum leaks. What do the plugs look like? How old are they?
Plugs are new. No vacuum leaks have not done a pressure or compression test
