p1799 Calculated oil temperature in use.
Has anyone gotten and fixed this code, cant seem to find anything on this at all. I have lost my passing gear also. Passing gear comes back at different times though.
Mine says calculated oil temperature used under transmission codes in scanner. Under data it said my trans is running 1025 degrees farenheit so something is wrong somewhere. Fluid is fine and red so not burning up yet.
I just found this. Looks like a bad trans temp sensor:
When Monitored and Set Condition:
P1799-CALCULATED OIL TEMP IN USE
When Monitored: Whenever the engine is running.
Set Condition: The DTC will set if any of the three conditions are present. Thermistor
voltage (Transmission Temperature Sensor) out of range. Continuous erratic thermistor
voltage is sensed. Thermistor Temperature stays low for an extended period of time.
Possible causes:
intermittent wiring & connectors
speed sensor ground circuit open
transmission temperature sensor signal circuit open
transmission temperature sensor signal circuit short to ground
speed sensor ground circuit short to voltage
transmission temperature sensor signal circuit short to voltage
transmission temperature sensor - inoperative
tcm - calculated oil temp in use
tcm - transmission temperature sensor high
tcm - transmission temperature sensor low
test
test
Trending Topics
Today I changed my solenoid pack and range sensor. While under truck I changed the pressure transducer, had a crack on top of it. I did a relearn after clearing p1799 code and everything went fine. The problem is I took it for two drives and still have no power taking off and no kick down in high gear. Overdrive button works when pressed off and on. I am stumped no codes at all in truck this problem comes and goes while sometimes driving it comes back but then goes away again. Parts used were mopar parts. Thanks
Truck is finally back to normal did a couple of relearns. I will say if you are running a 45rfe that has a solenoid with black connector update it to the white connector with new range plate. Removes any engagement noise you get when you put it in gear and
I have no hesitation on throttle at take off and passing gear is much better.
