2006 Ram tranny slip
2006 Dodge Ram Hemi. Does the torque converter drain off every time the vehicle sets idle a day or two? Seems like it is slipping for about 10 to 20 yards at initial takeoff. Then, does not do this throughout the day. Has been doing this for a long time. Does not get any better or worse. Is this normal?
He said 06 Ram hemi. Since it's an auto, it's a 545RFE (no other option). Sounds like converter drainback, were filters done recently? There have been issues with aftermarket filters, the internal check valve allows fluid to drain back out. It doesn't hurt anything, other than the fact that you have to wait for the pump to refill the converter. Next filter change put oem filters in. If it works fine the rest of the day that's most likely what it is.
