Fog light issue?
Hello, I'm new here. Please help!
I have a 2004 Dodge Ram 1500 that didn't come with fog lights. I installed a pair of factory ones and purchased the jumper wire that plugs into the fog lights and to the existing plug already there and looks as though it ties in with the headlight wiring harness. I tried pulling on the headlight switch as directed but it doesn't pull out. There's already a fuse and relay for fog lights in the fuse box. Not sure where to go next... I did just see on EBay a headlight/fog light switch that can actually pull out for fog lights. If I get this switch, will they turn on? Or do I need something else? Keep in mind that the truck did not have fog lights in it when I purchased it.
Thanks, B
Thanks, B
Bsmurf
I have an 04 SLT. The SLT comes prewired for the fog lights. I bought some OEM fog light set and then the OEM switch for the fog light function.
All plug and play. Stay OEM with the parts and you should be fine.The cam-bus set up on these trucks sucks because you cannot add without the proper factory switches. My trans temp guage light in my A-pillar only works with the fog lights because of this. Would have had to run a separate wire throught the firewall just to power up this little gauge light.
Hope this helps.
Hope this helps.
Trending Topics
Wombat Ranger;
Hey, thanks;
I am a union electrician but am not a low volt tech. I took the thing to a guy who installed my alarm and he was the one who told me about that cam-bus thing???
Does your option leave that guage on all of the time? I only want it on when the headlights are on?
Can you give me an idea which is the dimmer wire?
It pisses me off every time it gets dark out and I have to put the fog lights on just to keep an eye on my trans temp.
Many thanks,
jfotsch
Hope this helps.
Hope this helps.
Wombat Ranger;
Hey, thanks;
Many thanks,
jfotsch
Hey, thanks;
Many thanks,
jfotsch
It's CAN bus (Controller Area Network) and that didn't start in the Rams until 2006. If you had an 06+ then you'd need the switch AND to have the lights activated in the computer. Prior to that isn't necessary.
Thanks for straightening me out on not understanding what I was even talking about!
Is it possible for me to tie my trans temp gauge light in with my headlights? It cannot be enough current to hurt.
Right now it is on with the fog lights. The guy owns a shop and does alarms and tint here in vegas so I believed what he told me.
I took it to him because I was getting strange voltages at the switch.
He told me I could not attach it to the headlights because it was a "can-bus"
Thanks for any help you can give me
