Higher amp alternator safe???
Old Jan 1, 2017 | 06:35 PM
jfotsch's Avatar
jfotsch
Default Higher amp alternator safe???
I got a OEM set of fog lights a few years back and noticed that when I have headlights on with them and the truck drops to the 500rpm idle they show some signs of dimming. Especially if I hit the windows at the same time.
When I first noticed this I purchased an alternator that pushes 173 amp max and is rated at 160 amps.
My truck came with a 136 amp alternator and also states 136 is max on build sheet.
Is this the largest the trucks' wiring will accept or am I ok in replacing the less amperage unit out for the higher one?
Unfortunately my year truck does not allow changing of idle with my tuner.
The last thing I want to do is cause some problems in my electrical/ecm due to using a device not rated for the circuit.
Thanks for any info,
OEM off-road 17's, BFG LT's, Airraid CAI, Cortex 3950, Magnaflow y-pipe, Detroit TT, Mag Hytec trans and rear, SRT A-pillar w/autometer trans temp, 190 t-stat, pwr stop drilled/slotted all 4, pwr wire, grnd TB
Old Jan 1, 2017 | 07:29 PM
p38251's Avatar
p38251
You will be good. The truck will only draw what it needs. Lights dimming is a common issue. Make sure you have a good battery as well.
Old Jan 1, 2017 | 07:33 PM
jfotsch's Avatar
jfotsch
Thank you,
Have been chicken to change them out not knowing if it would be OK.
COOL
Old Jan 2, 2017 | 12:30 PM
HemiLonestar's Avatar
HemiLonestar
Yep. Mine came with a 136a and when the bearing went I upgraded it to the factory 160a. Voltage regulation is controlled by the PCM, like jfotsch said, it will only draw what it needs. If you have a battery issue, that can cause all kinds of problems that a higher amp alternator will not solve.
Old Jan 2, 2017 | 01:53 PM
jfotsch's Avatar
jfotsch
Thanks,
I really do appreciate all of the help.
I do keep a good battery in at all times. I use a battery reconditioner/desulfator (smart charger)on all of my lead/acid cells. In fact the factory Mopar battery that came with the truck is sitting on my shelf with a glowing green indicator in it but the truck's computer does not like it so I put in a new one every 3-4 years. The desert is really bad on them.
I wish I could find an Optima that would fit and look right in my battery tray. I keep a red-top in the back cargo at all times just for when people ask for a jump because I do not feel safe doing that these days when cars are full of electronics?
thanks,
jfotsch
Old Jan 5, 2017 | 08:17 AM
lxman1's Avatar
lxman1
Site Moderator
That is normal at 500rpm, with the lights, blower and other stuff running. Not too many alternators can charge that much at 500rpm. I wouldn't worry about it. My 08 has done this since day 1.
