P1416
Old Feb 1, 2017 | 09:52 AM
dieseldick2's Avatar
dieseldick2
Cool P1416
Have a 2006 Ram 1500 with 5.7 hemi, code P1416 and dead miss. checked for voltage and ground at MDS solenoid, ground ok, no power with key on. Replaced solenoid and reassembled. has comperssion cranking, as soon as engine starts both valves on 6 quit opening. Unhooked harness at rear of intake to disable MDS- no change. Removed solenoid to check for cut orings,everything good. At a loss for where to go next.
Old Jul 25, 2017 | 08:15 PM
TIM0426's Avatar
TIM0426
I have an 07 Durango with same problem, what did ya find out? I really don't want to start dumping a lot of parts into it..
Old Feb 16, 2024 | 12:44 PM
Hemimike345's Avatar
Hemimike345
Well bud you need a new cam I'm, sure if it. I went through a similar situation with misfire codes and mds codes and then a PCM misdiagnosed faulty, if your valves are controlled with the cam the lobes are worn down not opening the valves
Old Feb 17, 2024 | 09:01 AM
7 year old thread? I would expect that he has the fixed by now.....
