Has anyone replaced their output seal on transmission?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have the slightest leak at the output seal of my transmission where the drive shaft slips in. I have yet to find any write ups or how to's.
I have the 545rfe transmission and it's a 2wd model.
Sorry read it wrong. Use a seal puller, maybe a little bit of a pain. Lube the new seal, ice a large socket to tap into place. Check fluid level after.
You only need the bushing if the shaft is grooved. It keeps the seal from getting damaged. For the extra money may want to order the one with the sleeve just in case. It's pretty simple to do. You may even be able to borrow a seal puller. A screw driver will work, be careful not to hit the shaft.
