Brake light issues
Old Apr 3, 2017 | 02:51 AM
mexicutioner's Avatar
mexicutioner
Default Brake light issues
Hello,
I was hoping to see if I can get some input on an issue I'm having with my 2003 dodge ram 1500. None of the break lights turn on, including the Center mounted stop lamp. I have replaced the main L/R side tail lamps and the brake light switch. Not really sure where to go from here. Any input would be greatly appreciated.
Old Apr 3, 2017 | 07:38 AM
Checked fuses?
Old Apr 3, 2017 | 02:00 PM
mexicutioner
Yes, and I double checked today. And I was sure that all of them were working, but found using one of those test lights that both sides of #32 (10A Right tail lamps), #33 (20A trailer park lamps), and #34 (10A Left tail lamps) fuses were not on. I have a chilton manual which shows the power to those coming from the park lamp relay.
The relays for the parking lamps, ac condenser and starter solenoid are all the same, so I switched between them a few times to test out the functionality of the relays, and found that all three of them work.
The tail lamps on my truck are a dual fillament type. When I turn on the head lamps, they turn on. Turn signals are also turning on when I turn on the lights and they brighten up when I hit the turn signal on both directions.
I engaged the parking brake and placed truck in reverse, one of my reverse lamps is out, but I don't believe this would stop the parking lamps from turning on. I will get a replacement lamp to make sure the pixies aren't playing tricks on me.
Unfortunately, as I go through with this, it seems to be pointing at an issue in the Front Control Module or on the TIPM (Totally Integrated Power Module).
I may try to replace the brake lamp switch again. I did remove it from its bracket and actuated the lever from fully extended to fully retracted in case I may have screwed up the installation, but the only thing I get is a light clicking noise somewhere in the dash.
If you guys have any input, please let me know.
Old Oct 1, 2017 | 08:20 PM
Anoop Cheriyil Joseph's Avatar
Default shows lamp out and all the lights goes off
why my 2003 Ram 2500 5.7 Hemi magnum shows lamp out and all the lights including indicator , headlights and brake lights do not work.. please help me if someone knows why?
Old Oct 1, 2017 | 08:50 PM
Burnt fuse somewhere, or fusible link.
Welcome to DF!
Old Oct 2, 2017 | 11:20 AM
M150's Avatar
M150
hi there, have you been able to resolve it?
thank you
