Overhead Console
Old 11-19-2005, 03:42 PM
Dagger213's Avatar
Dagger213
Dagger213 is offline
Default Overhead Console
Hello,
I have a '04 1500 st and I am interested in installing the overhead console. Is it worth it and how hard would it be to do?
Thank You
Joe
Old 11-20-2005, 11:57 AM
osteodoc08's Avatar
osteodoc08
osteodoc08 is offline
Default RE: Overhead Console
I think a few other ST owners have done this, but honestly, I don't think I use mine enough to warrant the expense of putting it in if I didn't have it. I usually just leave it on the compass/temp. MPG is usually too painful to look at and I can keep up with the mileage with the dash trip odometer.
Old 11-22-2005, 05:01 AM
hemi24s's Avatar
hemi24s
hemi24s is offline
osteodoc is right i have one and i never have it on unless i have friends in the truck or am showing off . unless you have kids and planning on going on a trip i wouldnt get one. if you want something similar get a navigation system.
Old 11-22-2005, 09:24 AM
mill500's Avatar
mill500
mill500 is offline
I'm with these guys...I've got one too, but I don't think I'd add one. If you're convinced to do it, check with a dealer and see if Mopar makes a kit for it, and if you have an existing wiring harness to just plug it in. Shouldn't be too hard of an install then...probably pull out the head liner and pillar covers. I'd definately say NFW if you have to hunt down and splice wires.
Old 11-22-2005, 10:34 AM
stump_breaker's Avatar
stump_breaker
stump_breaker is offline
Hey Joe. I'm willing to bet money the hook-ups are already installed in your truck for the center console. I bought a base '05 truck and had them add what I wanted. Everything just "plugged and played" so to speak so I'm willing to bet it would not be that hard. My suggestion is if you have one out of a loaner truck, either remember the way it came out and reverse install it or have the dealership put one in - assuming you can afford the screwing you will get. I'm pretty sure the PC will need to be re-programmed so you will be taking a trip to the dealer anyway.
Old 11-22-2005, 01:55 PM
GotHemi?'s Avatar
GotHemi?
GotHemi? is offline
Jeez, I really appreciate my little computer buddy up there. I love zeroing out the MPG setting and the hitting the gas from a standstill. It reads like 4 miles to the gallon when you do that. Same is true at highway speeds when you reset it and take your foot off the gas, it shoots up to 99 miles to the gallon. I wish.
Old 11-22-2005, 06:18 PM
Dagger213's Avatar
Dagger213
After reading the replies, I decided not to go with it. I realized it just wasnt worth the time or money.
Thanks for all the help.
Joe
Old 11-22-2005, 07:00 PM
osteodoc08's Avatar
osteodoc08
No problem
Old 01-09-2006, 02:50 PM
eltupac's Avatar
eltupac
eltupac is offline
was the harness there? did you check?
Old 01-09-2006, 03:29 PM
Daddywags's Avatar
Daddywags
Daddywags is offline
ORIGINAL: osteodoc08
Just turn the instant miles setting on
Quick Reply: Overhead Console
