3 beeps when key removed from ignition
Old Apr 9, 2017 | 10:30 AM
anthonyflhx's Avatar
anthonyflhx
Default 3 beeps when key removed from ignition
I'm not sure if this is normal or not and hoping someone can help me out. Just got an 03 dodge ram 1500 4.7l v8 quad cab. When I remove the key from ignition it beeps 3 times. Not normal beep like seat belt sounds.
could the truck have alarm? I didn't get much information from previous owner and no manual at this time.
Old Apr 10, 2017 | 10:09 AM
cruzer55's Avatar
cruzer55
I know of a few aftermarket sound systems that give a 3 beep from the speakers that there is not an amplifier in use(or needs plugged in).OR is alarm system on?Depending on factory system need to check with any MOPAR dealer on which system is in veh and operating acc.Just a thought!!!!!!!!
Old Apr 11, 2017 | 10:44 AM
66three83's Avatar
66three83
Aftermarket stereo is most likely.
Old Apr 12, 2017 | 06:47 AM
anthonyflhx
Its an aftermarket radio, Sony xplod. Could the beeps mean the radio wasnt hooked up correctly?
Old Apr 12, 2017 | 08:18 AM
cruzer55's Avatar
cruzer55
It's hooked up correct.There are 3 setup on the back Contact sony or stero shop to get a instruction book for it .I have a 5705 Xplode in my ride with just a sub.It fills a standard cab just right.........Xplode systems are also XM ready and play MP3
Old Apr 15, 2017 | 05:09 PM
66three83's Avatar
66three83
I have one of those in my boat. When the power is turned off the unit beeps.
