no crank no start advice needed
Old Apr 24, 2017 | 07:01 PM
David2022's Avatar
David2022
Default no crank no start advice needed
2003 Dodge Ram 1500 360 motor
sat through winter went to start it battery was dead
replaced battery with new tried to start. Truck now has no dash warning lights only shows odometer and gear select fuel pump doesnt engage no crank no start overhead center has no display radio will come on but has no sound flashers work interior lights work I also replaced ignition switch any suggestions? I'm at a loss at this point
Old Apr 24, 2017 | 07:36 PM
p38251's Avatar
p38251
Check fuses and relays. Look for critter damage
Old Apr 24, 2017 | 07:56 PM
David2022's Avatar
David2022
Fuses are all good as far as I can see any specific ones I should double check? and I looked pretty much every where for nests nothing I even went as far as tearing the dash apart to find anything that could lock me out
Old May 3, 2017 | 02:53 PM
BigHorn70's Avatar
BigHorn70
Default No crank
check ground motor
Old May 10, 2017 | 09:31 AM
David2022's Avatar
David2022
Still having this issue I can put power to the starter from the ignition with a outside power source and crank just fine. I have power everywhere I should to the ignition just no dash lights no crank no fuel pump could the ignition switch be faulty? Could the immobilizer be bad? My obdll port is also dead we tried putting a computer on it and nothing
Old May 10, 2017 | 09:51 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
It could be bad. Take your battery terminals OFF and tie them together for about 30 minutes. Make sure the battery is charged before you do this because if you reconnect the terminals to a dead battery, it might put the module back to sleep again.
FYI, most of the time the OBD connector power and Immobilizer module are on the same fuse.
Old May 10, 2017 | 10:15 AM
David2022's Avatar
David2022
I will try it and we checked every fuse in the block with a voltage meter
Old May 13, 2017 | 11:39 AM
TNtech's Avatar
TNtech
Use a standard test light for that. Both sides of the fuse.
