2005 Ram 1500 4.7 gas Misfire Cylinder 8
Old 06-24-2017, 10:36 AM
Andrew Griffin's Avatar
Andrew Griffin
Andrew Griffin is offline
Default 2005 Ram 1500 4.7 gas Misfire Cylinder 8
Driving back from fishing spot water pump blows sprays coolant and water all over under the hood. Almost immediately check engine light comes on TPS code is sent. Limp it back home enroute I feel a misfire going up a hill. Get it home recheck codes P0300 General misfire code. Get new TPS and Water Pump replace clears codes. After couple miles check engine light again. P0308 Misfire Specific to cylinder 8. Buy all new spark plugs change move coil packs between cylinder 4 and 8. Same misfire. Replace fuel injector still cylinder 8 Misfire. Any help would be appreciated.
Old 06-24-2017, 10:43 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Welcome to DF. Moving this to Third gen ram section for ya.
Old 06-25-2017, 02:23 PM
superdak05's Avatar
superdak05
superdak05 is offline
while driving it home could have ran it hot and split a head gasket, if that's the case not good. upon start up, remove rad cap, if you see bubbles or back flow, head gasket is gone.
