2003 4.7 auto 4wd stalling when put in forward gear
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Truck stalls out when put in forward gear, ran codes p0700,p0846,p0871 came up. Have changed input/output speed sensor, fluid pressure sensor, any suggestions what it could be?
sounds like your torque convertor is acting up, try pushing the throttle a little when going into drive, might need a little umph getting it to go, if this works, might need a trans service.
