How much PS fluid?Hey Guys
Old Jul 13, 2017 | 01:54 PM
bakerman's Avatar
bakerman
Default How much PS fluid?Hey Guys
Hey Guys!
The truck's an '03 1500 4X4 4.7L V8.
I need to change my power steering fluid but can't seem to find how much fluid (ATF+4) I should have on hand for this job.
It's really expensive over here and I don't want to buy too much...
Any help on this will be very much appreciated.
Cheers!
Old Jul 13, 2017 | 02:28 PM
You already changed the pump once, didn't ya? Is this with pump number 2? If so, I wouldn't bother flushing the system, just install the new pump, fill and bleed the system, and call it a day.
Old Jul 14, 2017 | 07:51 AM
bakerman's Avatar
bakerman
The remanufactured pump that I installed burned out in less than 3 weeks...
so I'm repeating the procedure. Just can't remember how much fluid I used.
Old Jul 14, 2017 | 07:57 AM
Fill the reservoir up, start the truck, move the wheel side to side an few times, check the level, top off. Have a couple quarts with you.
