Do You Run A Rear Sway Bar? I Need One!
Old Jul 15, 2017 | 09:26 PM
Big Joe C's Avatar
Big Joe C
Default Do You Run A Rear Sway Bar? I Need One!
Hello 3rd gen friends! I have ventured over from the 2nd gen side with a question. I recently swapped in a Chrysler 9.25 from an 02 1500 into my 01 1500 to have disk brakes on all for corners. Runs drives and stops fantastic but I'm having some issues locating a rear sway bar.
I purchased a Hellwig 7626 bar and it did not fit. The bar was not wide enough. I know for a fact the shock mounts are farther apart on the 02+ 9.25s then they are on the 01 and older 9.25s.
Hellwig lists that it will fit so going back and forth with them for a week taking measurements and pictures, and checking other bars by them we came to the conclusion that none of their bars would fit.
So here I am back to square one looking for a rear sway bar. My Ram is a reg cab short bed 4x4 with a small lift so body roll is real.
If you run a rear sway bar on your 1500, what kind are you running? Pics are appreciated!
Old Jul 16, 2017 | 10:36 AM
Didn't some of them come stock with a rear sway bar?
Old Jul 17, 2017 | 10:52 AM
HemiLonestar's Avatar
HemiLonestar
Not on the 1500's. Only 3rd gen Ram 1500 that came with a rear sway bar was the SRT reg cab.
Old Jul 17, 2017 | 05:27 PM
Big Joe C's Avatar
Big Joe C
And the SRT10 had a Dana rear, so that wouldn't fit the Chrysler 9.25
