LED turn signal bulbs
Old Aug 15, 2017 | 12:35 PM
Honky_Tonk's Avatar
Honky_Tonk
Default LED turn signal bulbs
I recently replaced my turn signal bulbs with LEDs ('06 Ram 2500), now when I turn them on it blinks properly 4 times then flashes fast. Was looking to just put in an electronic flasher (I had done this before with a different vehicle) but auto parts store does not even list a flasher for the 2500 only a 1500. Is there a flasher on the 2500 or is it integrated into something else?
Old Aug 15, 2017 | 03:25 PM
Flasher should be exactly the same part as the 1500.
Old Oct 18, 2019 | 03:51 AM
Bryant Gelinas's Avatar
Bryant Gelinas
Default Led turn signals
Did you ever get your signals to flash correctly? My '05 dakota does not have a flasher fuse to replace. Put in high dollar bulbs and quick flash, except when hazards are used.
Old Oct 18, 2019 | 07:34 AM
If you can't use a flasher, you need to install resistors to prevent hyperflash.
https://www.vleds.com/hyper-flash-fix-load-resistors
Old Oct 19, 2019 | 01:07 AM
66three83's Avatar
66three83
Everything is controlled by the TIPM. Remove the LED’s before you blow out this $700 module. If you don’t know what that is, look it up.
Old Oct 19, 2019 | 01:10 AM
66three83's Avatar
66three83
Crap, got involved in an old thread again! Why are you posting about a Dakota here anyways? This is a Ram forum!!
