Headers
3 times is a charm..... 04' 4WD 1500
Ram/Hemi 5.7 . what header to use? shorties? anyone do this yet? do pipes need modified? does it change emissions, live in Milwaukee. also 4WD lite doesn't come on, does go into 4WD any thoughts?
As far as the 4wd light I don't know exactly but could just be a sensor, just a stab in dark.
Why do you want headers? Shorties won't really add anything. With shorties though, most will mount right up to the factory down pipes. Long tubes will require pipe work. As long as you get emissions compliant headers, it should not affect emissions ( O2 bungs present to mount the O2 sensors)
I'm about to install a set of Pacesetter LT headers with the Pacesetter Y pipe and do a cat delete. I know in some states you can get away without cats and in others they strictly enforce it. I'm going to be running 3" pipes and putting a 87MM ported TB with a TB spacer next. I currently have a K&N CAI and superchip tuner but I'm going to switch to Diablo T1000 for custom tunes.
