08 Ram won’t start plz HELP
Old Oct 6, 2017 | 09:31 PM
08RAMON35's Avatar
08RAMON35
Default 08 Ram won’t start plz HELP
MY 2008 Ram with a 4.7 won’t start. Just put a new starter, TIPM, and battery in the truck. You can see it desperately try here
sorry you can hear my charger idling right beside me
Sat for maybe 3-4 weeks at most
Old Oct 7, 2017 | 03:04 PM
TrueDogman's Avatar
TrueDogman
Trying to figure out your video. If im reading it right it seems like you may have a cylinder full of liquid...like antifreeze. I would pull out all the spark plugs and watch for wetness. Once all are out then turn the key to spin it over and see what happens...
Old Oct 7, 2017 | 07:49 PM
08RAMON35's Avatar
08RAMON35
Yea sorry about the confusion. I will have to try that tomorrow. I was told it could be a bad ground but I tried grounding it out on the block and frame and it didn’t not change a thing.
Thanks for the reply!
Old Oct 7, 2017 | 09:25 PM
TrueDogman's Avatar
TrueDogman
In the video are you cycling the ignition to the start position back and forth?
Old Oct 7, 2017 | 11:47 PM
08RAMON35's Avatar
08RAMON35
. No I am holding it in the start position until it completely stops trying to turn over
Old Oct 8, 2017 | 08:47 AM
TrueDogman's Avatar
TrueDogman
Another option is trying to turn the engine over by hand. Use a Johnson bar and socket on crank pulley. Turn in proper direction.
Old Oct 8, 2017 | 08:57 AM
superdak05's Avatar
superdak05
could possibly be the crank shaft sensor
Old Oct 8, 2017 | 10:42 AM
08RAMON35's Avatar
08RAMON35
I pulled the plugs out just now and turned the engine by hand. I can get it to turn fairly easy. No water in engine and even with one plug out of each cylinder it still does the same thing minus the back spin it was kind of doing in the video
Old Oct 8, 2017 | 10:43 AM
08RAMON35's Avatar
08RAMON35
I’m open to all the possibilities at this point. I will have to look into that. Thanks!
bdhuntr's Avatar
bdhuntr
Hard to tell, especially with your Charger idling next to it lol, but it looks and sounds as if as soon as the starter begins to engage, it shuts down. Have you tried removing the starter and and turning the key to Start and see if the starter is operating normally?
