This ones got me stumped...brakes or trans?
Old Nov 20, 2017 | 10:32 PM
darndodge's Avatar
darndodge
So got the Ram down to the garage this past weekend and raised the entire front-end. .Passenger side checked out ok but drivers side hub had back and forth wobble/slop..Does seem the bearing is on its way out. Gonna try to do this repair myself this weekend..Of all the parts stores only a few had in stock at about $120..I can get it online for $40-$50..Would the cheaper cost bearings be that much less quality than AutoZone product??..thx
Old Nov 21, 2017 | 10:11 AM
Go with a good quality bearing. If you go with the cheap feller, chances are you will be doing the job again within a year. (I have seen them fail in as little as a couple months......) Be sure and torque the nut down to the proper value as well, otherwise, the bearing, no matter the quality, simply won't last.
Old Nov 21, 2017 | 10:31 PM
darndodge's Avatar
darndodge
Hear that..Decided to dish out the $120 +tax. They said it was manufactured by Moog for AutoZone but they had another bearing for about $180 under the Moog brand so not sure what to think bout it all..Hope Im not getting the $50 Chinese bearing with a huge markup..Its actually very heavy and looks well made in my opinion coming from a machinist/fabrication background. Anyways got my work cut out for me this holiday weekend.. thx for the info guys!
Old Nov 25, 2017 | 12:09 AM
darndodge's Avatar
darndodge
Just an update..of my failed attempt at the repair...Things were going fine on disassembly until it was time to push the cv axle back to get to the three hub bolts..As some might have guessed the axle was rust seized..Pullers, sledges, heat nor penetrants would touch it..And to top off the misery my tied off caliper come loose fell down and snapped the brake hose..really sucks and seems that its time to remove the spindle assembly. Cant think of trying anything else except a 30ton press..right?
Old Nov 25, 2017 | 11:39 AM
That axle really shouldn't hang on that tight. Squirt some GOOD penetrant at it, (liquid wrench, PB Blaster, etc. NOT WD-40.....) Loosen the axle nut, put a punch in the little divot in the end of the axle, and SMACK IT with a big farking hammer. It'll come loose.
Old Nov 25, 2017 | 07:10 PM
darndodge's Avatar
darndodge
Believe me..done all I could.
With hub nut off..air hammer w/point bit, sledge w/point chisel, then put the nut back on end threads and whopped it with the backside of a 15lb splitting maul..I read horror stories about this so I guess my luck run out lately and in the same boat as the unfortunate lol.
Old Nov 25, 2017 | 11:01 PM
How much for another axle? and just replace that as well......
Old Nov 25, 2017 | 11:02 PM
66three83's Avatar
66three83
That’s a job best left to a pro. Especially if you’re in the rust belt. Let someone else beat themselves up over it!!
Old Nov 25, 2017 | 11:07 PM
I live right smack in the heart of the rust belt.... and I have never encountered one I couldn't get out...... That's just bizarre.
Old Nov 26, 2017 | 11:30 PM
darndodge's Avatar
darndodge
Not sure if Kentucky is considered in rust belt. This is my third dodge and is starting to get as rusty as my 98 did. I can believe it seized that bad after seeing what condition the brake hose was in. Good thing my caliper fell off the wire or I'd been out driving and eventually lost my brakes. The brake hose snapped in an area where it nearly rust through. Anyways got the new brake hose on and bled. All parts are back on and just plan on tackling the hub bearing another time.
