Detroit Truetrac questions
Old Nov 21, 2017 | 09:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Question Detroit Truetrac questions
Hey has anyone installed a Detroit Truetrac in their truck? It looks like this is the closest to a selectable locker that is available for the Chrysler 9.25 (I know it is an LSD ). I have the Lock-Right No-Slip in my old Dodge truck and it does work great as it is a true locker, but its street manners suck. I want to see if the detroit truetrac is as gental as a normal LSD is on the street. Also, from what I have read it is not a 50/50 which makes a locker, but can get 60/40 which puts it closer to a LSD but better. For those who use it off-road does it give you enough traction when offroad? Any other options for a selectable locker for the Chry 9.25 that I don't know of?
Old Nov 21, 2017 | 10:08 AM
The truetrac is a geared LSD, so, no clutches to wear out, no requirements for special additives, etc. It isn't as robust as the detroit locker, but, road manners are MUCH better. The military likes them in the H1 hummers, and I haven't seen anyone complaining about manners, or performance..... So, as an alternative to a locker, it is actually pretty good.
Old Nov 23, 2017 | 08:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya for this truck I need good street manners due to my wife may need to drive it every now and then, and I don't want her to have to baby the way she drives it.
I can't believe after all these years the 9.25 has been around they are no selectable lockers available. ARB was in process of making one, but that was 10 years ago, I guess they dumped the project.
Old Nov 27, 2017 | 09:00 AM
00t444e's Avatar
00t444e
If you don't want a auto locker in the rear then the truetrack is the next best choice. It isn't a locker it is a limited slip that uses gears to transfer torque to the wheel with more traction. It is very street friendly and smoother than a clutch type lsd. The only drawback is that each wheel has to have some traction for it to be able to transfer torque, so if you have a wheel in the air or on slick ice it won't be able to transfer enough torque to the other wheel, in this type of situation you can apply the brakes to put some resistance on the spinning wheel so it can transfer torque to the other wheel that has traction.
