AC/Heat Blower issues
Old Dec 19, 2017 | 09:21 AM
tejasme's Avatar
tejasme
Default AC/Heat Blower issues
I have read so many posts (others sites as well) concerning the issue of AC/Heat blower either working intermittently or not at all, on Dodge vehicles of just about all year models. WHY hasn't Dodge corrected this problem?!
In March of 2017, I had the resistor changed out (now I know how to do it myself) and the thing seems to have gone out again this week. I would like to see a discussion on what causes this resistor to overheat and how to guard against this issue. My 2008 Ram 2500
Old Dec 19, 2017 | 09:53 AM
primem's Avatar
primem
they do mean time to failure analysis on every part; for a 9 year old resistor to fail, its pretty much surpassed its working life.
Old Dec 19, 2017 | 12:26 PM
tejasme's Avatar
tejasme
My point is that this is evidently an on-going issue for Dodge (Many owners from years back to current have the same issue) and they have not fixed it. This is my 2nd one to go out just since March of this year. I would like to see knowledgeable discussion on what causes this.
Old Dec 19, 2017 | 09:38 PM
The resistors gets hot, which is really their job..... If you have a questionable ground, or a motor with bearings that are getting tight (ready to fail....) that puts a higher load on the circuit. Higher load equals More heat equals faster burnout. Also, I think it is supposed to be at least partially cooled by airflow thru the heater box, so, some obstruction that prevents the resistor block from getting adequate airflow will also hasten its demise.
Old Dec 20, 2017 | 09:33 AM
tejasme's Avatar
tejasme
Thank You, 'HeyYou'. This makes sense and now I know what else to look for. This is really a good p/u and I want it to last a whole lot longer!
Old Dec 20, 2017 | 10:12 AM
Part quality also plays a major role there..... If the aftermarket fellers aren't lasting long, getting a mopar unit *might* help.
Old Sep 15, 2019 | 11:07 PM
Tom Masengale's Avatar
Tom Masengale
So I was just going to change my blower motor on my 06 mega cab now the question is it clockwise or counterclockwise? Help
