Headlights and fog lights
Old Dec 21, 2017 | 12:38 AM
Brandon Gray's Avatar
Brandon Gray
Default Headlights and fog lights
Could my fog lights being tied into headlights cause lamp out and headlights not to work?
Old Dec 21, 2017 | 06:50 AM
Are they aftermarket?
Old Dec 21, 2017 | 08:34 AM
Brandon Gray
Yes they are LED lights and a jumper wire ran from there to actual headlight wire
Old Jan 1, 2018 | 10:37 PM
bigreed91's Avatar
bigreed91
Instead of running them straight off of the headlight wire run a relay off the headlight wire to activate the fogs, it'll be less load on the headlight circuit.
Old Jan 2, 2018 | 11:07 AM
Yeah, you need to wire them up properly using a relay and a switch. You can cause your wiring to burn up that way.
