04 5.7 hemi ignition coil b secondary circuit p2305
Old 01-10-2018 | 11:48 PM
ando37's Avatar
ando37
The code for me is ignition coil A secondary circuit also wit multiple misfires and misfire cyl 4
Old 01-11-2018 | 11:01 AM
justin0943's Avatar
justin0943
Originally Posted by ando37
When u changed the coil and plugs it came back? I’m goin thru same thing brand new plugs coils from my 2005 truck had no coil problems so I used those thinking it wud be okay but nope p24 code and p0300 and p0304 so I’m gonna get new coils but it seems like that didn’t help.. did u change injectors did that do anything to stop misfire?
yeah I swap injector and it stayed at b still, try replacing the cam and crank sensor if that doesn't help then it maybe deeper problem like flat cam or lifter problem so do a compression test
Old 01-11-2018 | 11:03 AM
justin0943's Avatar
justin0943
try replacing cam and crank sensor
The following users liked this post:
Hemi_Guy12 (03-03-2024)
Old 03-03-2024 | 05:13 PM
Hemi_Guy12's Avatar
Hemi_Guy12
Default P2305
Just wondering? Did you try the crank sensor or camshaft sensor? I have a 2012 Ram sport that has a p2305 and I’ve replaced the plugs in cylinder 2 and the coil pack. Those were my next step.
