HoAt Vs oat coolant
Old Dec 28, 2017 | 07:30 PM
mbauer's Avatar
mbauer
Default HoAt Vs oat coolant
2006 4.7. I'm replacing my thermostat and I bought the oat coolant which is purple, I didn't know Chrysler changed coolant. Anyway mine was orange. Is this purple coolant safe for my engine?
Old Dec 28, 2017 | 11:38 PM
primem's Avatar
primem
nope, you need hoat coolant not oat. if the 2 are mixed they will gell. you would have to drain and then flush the system 2x with water to fully get the old coolant out. the new coolant is longer life but is also more compatible with the new materials in the new engines. just stick with the hoat coolant your vehicle was designed for.
Old Dec 28, 2017 | 11:50 PM
mbauer's Avatar
mbauer
I bought oat on accident, I have 2 gallons, if it's save to run with flushing I would rather do that then waste it
Old Dec 29, 2017 | 07:47 AM
You can't return it, and get the right coolant?
Old Dec 29, 2017 | 09:38 AM
mbauer's Avatar
mbauer
I already mixed it
Old Dec 29, 2017 | 10:01 AM
primem's Avatar
primem
this means what?
if you already mixed it will hoat...its junk. flush the system as directed
Old Dec 29, 2017 | 10:09 AM
mbauer's Avatar
mbauer
this means what?
mixed with distilled water. I haven't put any in
Old Dec 29, 2017 | 10:19 AM
primem's Avatar
primem
save it for when you buy a 2013 or newer fca vehicle.
under no circumstance can the 2 coolants be mixed
Old Dec 29, 2017 | 10:37 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
^ This.
To the OP: You made a mistake. We all do that. The problem is you're subscribing to the Sunk Cost Fallacy. Find someone who can use the OAT coolant or else dispose of it, but don't get dead set on using it in your present vehicle. The cost of this lesson learned is cheaper than the alternative.
Old Dec 29, 2017 | 09:29 PM
Originally Posted by Gary-L
^ This.
I gotta agree with Gary here. No matter how thorough you flush it, you aren't going to get all the old coolant out......
