06 Ram starting issue
hey guys it's been a long time since i have been on here but i have a question that hopefully someone can help me out with. I have a 2006 Ram quad cab 4x4. i went out yesterday to start it for work and it just cranked really really slow. i figured it was the -11 degrees outside that drained my battery so after work i got a new battery and it still cranking very slow and will not start. (on a side note it was cranking slowly through out the summer too so i figured the battery was needed.) anyways i spoke to a buddy of mine and he said that it sounded like the starter. i asked even though it is still engaging? he said yes it could be.
what do you all think? i ordered a new starter today and we will see but i wanted to still check it out with you guys to see if you all think the same thing.
thanks
JT
thanks
JT
Thing to do would be a starter draw test. Of course, that would involve getting it close to the test instrument...... Don't know if the parts stores rent those or not.....
But, yeah, it's entirely possible the starter is failing, and giving you the slow crank. If it was doing it already this summer, then the COLD weather will only make it worse.
thank you i just needed another opinion on this i will switch the starter out tonight and we will see. thank you
In the TIPM, Fuse 10, 5 amp. Check it, make sure it is good. (if you have another one, just replace it.)
The ignition switch sends power to the starter relay, then to the PCM, PCM controls the ground for the circuit.
PCM gets input from the TIPM as well, thru the P/N switch. I would assume the PCM needs to see some voltage there, in order to ground the starter relay control circuit. (connector 3, yellow with dark blue trace, pin 21.) See if you are getting anything there. (going to require a volt meter, and a second body......)
Trending Topics
i was wondering the same thing last night. i am getting irritated that's for sure. It was working fine until we got this cold spell and it sat for three days un-driven. now im so confused i have never seen the drive-line indicators all have squares around them like they are all in gear at the same time. i really thank you for the help you have tried giving me. lol
