Seatbelt alarm
Old Nov 30, 2005 | 03:29 AM
arkid's Avatar
arkid
Default Seatbelt alarm
I have an 06 QC and it has an annoyong seatbelt alarm if you drive without it on. I'm used to unclipping my belt as I turn onto my street but this dam thing keeps going off. Is there any way to disable this alarm.
Thanks.
Old Nov 30, 2005 | 04:11 AM
uawnick's Avatar
uawnick
Default RE: Seatbelt alarm
use the buckle from the center seat... thats what I do
Old Nov 30, 2005 | 06:36 AM
GotHemi?'s Avatar
GotHemi?
Check your owners manual. It says in there. You can't turn the light off though.
Old Nov 30, 2005 | 08:51 AM
shoedork's Avatar
shoedork
start with the truck turned off, buckle your seat belt, start your truck wait for the seat belt chime to stop then unbuckle and re-buckle your seatbelt 3 times quickly (you should end up with your seatbelt buckled when finished) then turn off the truck and you should hear a chime, that means you did it correctly. You have about 20-30 seconds i think to do this sequence. I am almost totally positive that this this is how you do it, but like mentioned above double check your manual, thats wear i found it.
Old Nov 30, 2005 | 01:49 PM
arkid's Avatar
arkid
Thanks!!!!
yeah I guess it would help if I read the manual.
