Fan Not Blowing on Low settings
Old Mar 1, 2018 | 07:38 PM
Zarlandaris's Avatar
Zarlandaris
Default Fan Not Blowing on Low settings
2008 Dodge Ram 1500 - 5.7L
My fan blower is not responding on the first three settings. It only blows on the highest settings, and smells of radiator coolant.
I do not know if i need to change the resistor, or the fan blower itself.
Any help would be great, thanks
Old Mar 1, 2018 | 07:55 PM
MikeHTally's Avatar
MikeHTally
Bad resistor block. $50 and 30 minutes will get it running like it should.
Old Mar 1, 2018 | 08:02 PM
Zarlandaris
is this what im looking for?
Old Mar 1, 2018 | 10:58 PM
bigreed91's Avatar
bigreed91
Thats it (background info) all the lower speed settings use resistors to drop the voltage at the motor, as the speed goes up the setting has a lower resistor so more voltage is used at the motor. The high speed though has no resistor as it gets full voltage. Thats why when these go bad you lose all the low settings but retain high as it has nothing to fail.
