no overdrive
yes diesel ,yes shifting normally otherwise (for a dodge) lol
no trans temp light, o/d -tow haul light will turn off and on as I command , (so it works ) the total story is when pulling trailer on hiway it started to tach up about 200 rpm s when going up overpass in o/d then slipped momentarily then drove home 200 miles still slight 200 rpms in o/d . I changed pressure sensor and shift solenoid ans tranny felt good but no longer goes into o/d . took to some on that hooked up to computer while driving it and said pressures were good at times commanding 4th but not going in to 4th (sometimes) changed tcc and overdrive solenoid. so do you think maybe one of the ones I changed was bad also (even if pressures were good) or a different solenoid. BTW thanks for your time and thoughts
Trending Topics
Shouldn't tow in O/D..... the clutches simply can't hold on tight enough, and they slip, and burn.
The 200 RPM change is TCC engaging/disengaging. If it's 'bouncy', likely TPS is bad, or just flaky.
RPM should drop pretty good on 1-2 shift, and again on 2-3 shift, then slight drop when TCC engages, then a significant drop when it goes into O/D. Which one isn't happening?
