help decode my build sheet
Old Apr 8, 2018 | 07:49 PM
mopar4u's Avatar
mopar4u
Default help decode my build sheet
i dont have a tailgate ram badge, 4x4 badge, hemi badge or slt badge....safe to say its either been debadged or had panels replaced/been painted and no badges put back on?
what is the “* Mutually Exclusive Package”?
what is the “* Customer Preferred Package 2TG”?
what is the * “Customer Preferred Package 26G”.
STANDARD EQUIPMENT
* Monotone Paint
* 136 Amp Alternator
* 4 Wheel Disc Rr Anti-Lock Brakes
* Front Height Adjust Shoulder Belts
* Passenger Air Bag On/Off Switch
* Next Gen Multistage Front Air Bags**
* Floor Covering Carpet
* Front Floor Mats
* Passenger Assist Handle
* Overhead Console w/Trip Computer
* Behind the Seat Storage / Bin
* All 5-Speed Automatic Transmissions
* Man Shift-on-the-Fly Transfer Case
* 205MM HD Front Axle
* 3.55 Rear Axle Ratio
* Corporate 9.25 LD Rear Axle
* Tinted Glass Windows
* Rear Fixed Window
* Rear View Day/Night Mirror
* Passenger Side Sun Visor w/Mirror
* Power Heated Mirrors, Fold-Away
* Remote Keyless Entry
* Air Conditioning
Dash Liner Insulation
* Floor Tunnel Insulation
* Instrument Cluster w/Tach
* 120 MPH Primary Speedometer
* Var Intermittent Windshield Wipers
* Cigar Lighter
* Dual Note Electric Horns
* 12V Auxiliary Power Outlet
* Power Locks
* Power Windows, Driver One-Touch
* Glove Box Lamp
* Halogen Headlamps
* Cargo Lamp
* Bright Rear Bumper
* Body Color Upper Fascia
* Bright Front Bumper
* Front License Plate Bracket
* Bright Grille
* Ram's Head Badge
* SLT Badge
* 4X4 Badge
* Removable Tailgate w/Caliper Latches
* Front Air Dam
* Front Air Close Out Panel
* 26 Gallon Fuel Tank
* Speed Control
* Bright Silver Metallic Clear Coat
* AM/FM Compact Disc Radio w/Chgr Ctrl
* 4 Speakers
Rack and Pinion Steering
* 4-Spoke Steering Wheel
* Front Heavy Duty Shock Absorbers
* Rear Heavy Duty Shock Absorbers
* Front Stabilizer Bar
* Tilt Steering Column
* Full Size Spare Tire
* Tire Carrier Winch
* P245/70R17 BSW All Season Tires
* 17" Steel Spare Wheel
* 17X8.0 Steel Chrome Clad Wheels
* Non Adjustable Pedals
* Pickup Box
* Trailer Tow w/4-Pin Connector Wiring
* Build To U.S. Mkt. Specifications
* GVW Rating - 6350#
* U.S. Dealer Retail
* Zone 51-Chicago
* Four Wheel Drive (4WD)/(4X4)
* 6 FT. Cargo Box
* Regular Cab
* 1500 Series
* DR-Vehicle Family
* Vehicle Order Tracking
* U.S. Specifications Label
* Wisconsin Ship to State Code
* Wisconsin Sold to State Code
optional equipment
Cloth 40/20/40 Prem Bench Seat
* Dark Slate Gray
* Trailer Tow Group
* 750 Amp Maintenance Free Battery
* 40/20/40 Split Bench Seat
* Front Center Seat Cushion Storage
* 5-Spd Automatic 545RFE Transmission
* Lock-Up Torque Converter
* Anti-Spin Differential Rear Axle
* All Gas Engine
* 5.7L V8 HEMI Engine
* All Vehicles W/Power Mirrors
* Power Driver Seat
* Power 6-Way Driver Seat
* JET BLACK - Molding - Bodyside
* Bodyside Molding
* 50 State Emissions
* U.S. Emissions w/OBD 1
* EVAP Control System
* Auxiliary Transmission Oil Cooler
* Electronically Controlled Throttle
* Heavy Duty Engine Cooling
* Next Generation Engine Controller
* All Radio Equipped Vehicles
* Fixed Long Mast Antenna
* Michelin Brand Tires
* All Steel Wheels
Center Hub
* Class IV Receiver Hitch
* 7 Pin Wiring Harness
* Manuf Statement of Origin
* 4 Additional Gallons of Gas
* Spring - Left Front
* Spring - Left Rear
* Spring - Right Front
* Spring - Right Rear
* Customer Preferred Package 26G
* 4X4 Tracking
* ISVL Tracking
* Wisconsin Act-13 Recovery
* Waterbase Paint
* Paint Order Code
Old Apr 9, 2018 | 10:57 AM
