Electrical issue ( no start )
Old May 5, 2018 | 07:37 PM
sportsman70003's Avatar
sportsman70003
Ok got a question before I send of my PCM to get it flashed. I have a code P0633 skim key not programmed in PCM. Is there any way to run the vin and check to see if this truck came with the skim? It has the black dodge key and it don't have the skim module (unless removed by the previous shops that have worked on it). I talked to the guy at Auto Computer performance and he said for $175 he could take the security out of the PCM.
Old May 6, 2018 | 09:44 AM
Go here. Click on 'equipment listing', and on the page that comes up, enter your vin, and hit 'submit'. That will tell you everything your truck came with from the factory.
Old May 7, 2018 | 09:52 PM
sportsman70003
Looks like it didn't come with the skim. I have the factory alarm unarmed now. My problem now is when I try to start the truck the starer doesn't turn over. Took a test light and checked and its not getting 12v to the starter. I run a jump wire to the starter and it turned over but wouldn't run.
