Torque specs?
Old May 1, 2018 | 11:55 AM
BigHoss37's Avatar
BigHoss37
Default Torque specs?
ok so I'm replacing wheel bearings on my 2008 Dodge Ram 2500 4x4, anyone know the torque specs for this thanks I've heard 2 different numbers but not sure which one to go with 185 ft lbs or 263 ft lbs?
Old May 1, 2018 | 12:59 PM
http://www.skf.com/binary/81-66360/457377.pdf
Old May 1, 2018 | 01:05 PM
BigHoss37's Avatar
BigHoss37
I guess I don't know which one will work for me not sure what suspension I have I guess I do you know the difference?
Old May 1, 2018 | 01:23 PM
Do you have a solid front axle or independent suspension?
Old May 1, 2018 | 01:42 PM
BigHoss37's Avatar
BigHoss37
I guess I don't know I would have to look. but that sight said coil/link or independent and I don't know which that is either I guess any way to look it up do you know? thanks
the full description of truck is2008 Dodge Ram 2500 st4dr quad 4wd SB if that tells you anything
Old May 1, 2018 | 01:55 PM
Coils spring would be solid axle. Independent would be CV axles and struts.
Old May 1, 2018 | 02:03 PM
BigHoss37's Avatar
BigHoss37
ok I'll check it out when I get home Thanks
Old May 2, 2018 | 11:03 AM
BigHoss37's Avatar
BigHoss37
so I found out it is the solid axle and it will need to be torque to the 263 ft lbs thx
