03 ram 5.7 white smoke
Old May 8, 2018 | 05:23 PM
Hoyt41's Avatar
Hoyt41
Default 03 ram 5.7 white smoke
Ok just recently Ive noticed that after its warm and sits and idiols for a couple minutes when I hit the gas it blows white smoke out but then clears up. I know the usual suspect is a head gasket but ive been hearing it could be other things. I can work on most things myself so before going to a mechanic what should I do and look at to see if I can solve the problem. The truck has 175,000 miles on it and does use some oil normally.
Old May 8, 2018 | 07:30 PM
Test for combustion gases in the coolant. You can get the kit/chemicals from your local parts store.
