Dropped a valve spring keeper into the head
Old May 20, 2018 | 08:17 PM
Dwk's Avatar
Dwk
Default Dropped a valve spring keeper into the head
I'm changing valve springs on a 04 ram 1500, 5.7 hemi.
while installing to new spring on #7 cylinder intake valve a dropped one of the keepers. And before you ask, no I didn't stuff rags in the wholes next to the springs.
here's my question, will pulling the intake manifold get me to the lifters, that's where I think I will find the keeper, or am I going to have to pull the head?
Old May 21, 2018 | 08:22 AM
Gotta pull the intake to pull the head in any event. If you shine a bright light down the hole, can you see the keeper?
Old May 21, 2018 | 11:14 AM
HemiLonestar's Avatar
HemiLonestar
*holes
Oh lord, what were you thinking...yes you will have to pull the head to get to the lifters (which like HeyYou said requires pulling the intake anyway). Then you will need a new head gasket and head bolts (bolts are stretched as they are torque to yield). I know it'll be a bitch with a magnet, but have you tried fishing around to see if it grabs it?
Old May 21, 2018 | 11:37 AM
AJOSSY's Avatar
AJOSSY
Before you pull the the head try to fish the keeper out with a small magnet.
Could save you a ton of work and a lot of grief.
As you learned, a rag (or paper towel) stuffed in the holes is a good idea.
Old May 21, 2018 | 01:32 PM
Dwk's Avatar
Dwk
I have tried a magnet, but the one I have is a little to big, I'm going to stop and pick one up on my way home, and an inspe inspection camera to look down inside. Where this is at i can't get back there to see down in the hole.
