Oil pan removal
Old Jun 5, 2018 | 12:21 PM
Dwk's Avatar
Dwk
Default Oil pan removal
I'm about to drop the oil pan on a 2004 dodge ram 1500, 5.7 hemi. I noticed there is a bracket at the back that bolts to the bottom of the block, and to the transmission. It has to be removed becuase it covers the oil pan flange on both sides. It appears to have something to do with the transmission mounting to the engine. My question is should I block up the transmission before I remove this bracket?
Old Jun 5, 2018 | 01:20 PM
Moved to the correct section.
Old Jun 5, 2018 | 07:46 PM
It's just a brace, and there are still going to be several other bolts hold the trans and engine together.
Old Jun 6, 2018 | 12:40 PM
HemiLonestar's Avatar
HemiLonestar
No, otherwise it would cause stress anytime it was removed to access the torque converter bolts. You're good.
Old Jun 10, 2018 | 11:42 AM
Dwk's Avatar
Dwk
Default Thanks
Thanks guys, got it done
