Got a leak of energy
Old Jun 28, 2018 | 11:13 AM
BigHornUsa's Avatar
BigHornUsa
Default Got a leak of energy
I got a leak of energy since several weeks. After investigate i found on fuse 10, a leak of 1 ampera per hour. Its run ignition acc.. as i am leaving in belgium, can u suggest me where to search. I dont know what is acc, and have no reference for this.a » Alternator is new and starter also. Thanks for your help. Ed from Belgium
Old Jun 28, 2018 | 12:00 PM
HemiLonestar's Avatar
HemiLonestar
Acc = accessory (if you are referring to key position). This key position will allow certain things to have power when the truck isn't running.
Old Jun 28, 2018 | 12:34 PM
BigHornUsa's Avatar
BigHornUsa
Ok i will check but as accessories, i wonder what it can be. Can u tell me when i open a door, the consumption raise to 3.04 ampera. Can it be the lightbulb that consume that ampera? It seems to me high
Old Jun 28, 2018 | 03:29 PM
I don't think you can take the key out with the ignition in ACC position...... Is your battery going dead overnight?
Old Jun 30, 2018 | 01:19 AM
BigHornUsa's Avatar
BigHornUsa
Hello,
i have checked, and yes I can pull out the key in all positions, the neiman have a issue, but I can start the engine and it run perfectly.
How to test the Neiman. someone have a doc for changing the Neiman?
does the consumption of 3 amp. is logical when I open the door?
I cannot let the battery ON, cause it died in a few hours. the consumption should be 4 to 10 milliamp, not 1 amp. Thanks for your support guys.
Ed from Belgium
Old Jun 30, 2018 | 09:11 AM
Neiman?
Old Jun 30, 2018 | 01:22 PM
BigHornUsa's Avatar
BigHornUsa
Neiman?
neiman is the switch to run ignition engine. U can google it. I dont know the name in english
Old Jun 30, 2018 | 05:07 PM
If you have a drain, even with ignition off (key switch), check and see if a light isn't staying on. Glove box, under hood, etc.
Old Jul 2, 2018 | 09:13 AM
bdhuntr's Avatar
bdhuntr
Check the glove box. I had that same issue.
Old Jul 3, 2018 | 09:18 AM
BigHornUsa's Avatar
BigHornUsa
Default glove box
i dont think that the issue comes from the glove box, the bulb is broken. a bad bulb dont consume energy, or can it be?
