Parasitic Battery Drain
Old Jul 16, 2018 | 06:41 PM
RamMike's Avatar
RamMike
Default Parasitic Battery Drain
I have an 800 milliampere drain on my 2006 Ram 1500 that I need to jump start if I leave it sit for a day or less.
I hooked up a multimeter to monitor the current draw and when everything shuts down and the doors closed, it drops down to .8amps and stays there.
I pulled every single fuse in the under-hood fuse box and the current never dropped.
What's the deal? How could this be happening even when I pulled fuses?
Thanks!
Mike
Old Jul 16, 2018 | 06:48 PM
jrsick's Avatar
jrsick
Did you pull relays also?
Put in a new stereo recently?
Old Jul 16, 2018 | 06:53 PM
RamMike's Avatar
RamMike
No on the stereo.
It is my understanding that 06 Rams have NO relays. Instead, everything is controlled by the TPIM.
Believe me, I wish they had replays because then my intermittent wipers would work. :-(
Old Jul 16, 2018 | 06:58 PM
They have relays, they just aren't user-serviceable.
Old Jul 16, 2018 | 07:25 PM
RamMike's Avatar
RamMike
Tell me about it!
Bad relay, 20 years ago? 4 bucks, unplug, plug in new one, done.
Bad replay now? $750 for a new TPIM that will likely develop the same problem.
Old Jul 16, 2018 | 08:52 PM
rtmtrrdr's Avatar
rtmtrrdr
It’s supposed to have a .8 draw at all times when off. I had the same issue with mine. I did a lot of research and found that after the doors are closed and the lights and everything go off. The computer will drop the draw down to .8 just to keep its memory. Mine wouldn’t drop down to that. It would stay at 1.0 or more amps and by the next morning the battery would be dead. It turned out that my ignition switch was bad. I replaced that and now it drops down to .8 like it’s supposed to.
The problem with your wipers is the wiper motor relay is bad. The relay is actually attached to the wiper motor. If you look at it it’s the black plastic cup attached to it. I’ve heard that you can take it apart and clean the contacts then it will work. I didn’t want to do that,so I just bought a reman one from auto zone. The first one I bought from them was bad also. The second one was right and the intermittent wipers are working again
Old Jul 16, 2018 | 09:56 PM
RamMike's Avatar
RamMike
Great info, thanks!
.8 amps seems like a lot for sleep mode, but it is what it is.
Maybe my battery is going dead. Guess I'll take it to get a load test.
I will check out my wiper motor-- hope that's the fix. It's really annoying to not have the intermittent wipers.
Old Jul 17, 2018 | 08:53 AM
bdhuntr's Avatar
bdhuntr
Originally Posted by RamMike
Great info, thanks!
I had that same issue. Installed a new battery. Still had the same issue. First battery was factory and 9 years old. 2nd battery was bad from stock. Replaced under warranty and haven't had a repeat in over two years.
Old Jul 17, 2018 | 12:12 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
NO! .800 is not right. Maybe you forgot your 0. Spec is .030 or less. 8/10 of an amp is a HUGE draw.
Great info, thanks!
Pulling fuses alone is not enough to find a draw anymore. You might be in over your head.
Old Jul 17, 2018 | 12:18 PM
RamMike's Avatar
RamMike
I thought .8 was a pretty big draw.
I wouldn't say I'm in over my head, but I *am* in here asking for advice on how to find the 'leak."
Maybe in over my head on the how-to knowledge but not over my head on ability. :-)
Do you have any techniques you can suggest?
I've seen several decent youtube videos on it, but was hoping for something more Dodge specific.
