2008 Ram 1500 5.7 hemi running bad!!
Old Sep 22, 2018 | 05:34 PM
jgathman72's Avatar
jgathman72
Is that with the injector connected? If not, and there isn't a short somewhere in the wire between the injector, and pcm, that's a bad pcm.
Hello HeyYou,
Yes, the injector was disconnected and I got voltage on both wires.... I pulled the loom and traced the individual wires back to pcm connector and could not find a break, scuff, melted portion,,,nothing.....I also registered voltage (same) on the male pin coming out of the back of pcm .... so I guess that explains the error code of injector circuit open.... a bad pcm....
Hey I really appreciate all your help!!!!
Thanks again!
Old Sep 22, 2018 | 06:42 PM
Think I would test the wire and see if you get power, or ground out of it, with it disconnected from the PCM as well.
