Grinding/clunking in 2 wheel drive, goes away in 4.
Old Nov 5, 2018 | 01:14 PM
AlaskaJon's Avatar
AlaskaJon
Exclamation Grinding/clunking in 2 wheel drive, goes away in 4.
I have a 2002 Ram 1500, automatic transmission, 5.9 V8. Yesterday when i went to drive it, it had developed a grinding/clunking noise coming from what sounds like the front passenger side of the car. It's hard to exactly locate where the sound is coming from, but it's definitely the front. When I'm going fairly slow (<20 mph) it does it constantly and violently. I originally thought a rock may have gotten stuck under by break pad, but after driving a short distance, breaking hard, going in reverse, it's still there. I took the tire off to check the pads, and didn't notice anything. Put the tire back on, still there. For some reason, i decided to put my truck in 4x4 and the sound goes away, but comes back when i put it back in 2 wheel drive. I haven't gotten under it yet, but am looking for suggestions. I live in Alaska, so there aren't any options for salvage yards.
Like i said, i parked it and it was fine. Turned it on later that day and it had the described symptoms. No real build up from a small clunking noise to this, just boom, clunking.
With it going away in 4x4, I'm thinking maybe my transfer case? I can do a lot of mechanical stuff, but i'm in the dark on this kind of stuff. Any help would be appreciated. I found another thread, but their problem seemed to only last for a short time, mine is basically constant once i get over 10 mph. Under 10, fairly normal, over 10 awful, didn't try over 20 because of the severity of the noise (in 2 wheel drive).
https://dodgeforum.com/forum/2nd-gen...eel-drive.html
Thanks.
Old Nov 5, 2018 | 04:57 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Why did you post this in two different sections?
Old Nov 5, 2018 | 05:07 PM
TrueDogman's Avatar
TrueDogman
I would suggest looking at the front wheel hub and encased wheel bearing. I once had no noise or symptoms until, all of a sudden had similar symptoms except my front wheel was also locking up with no brakes applied.
Old Nov 8, 2018 | 11:58 AM
AlaskaJon's Avatar
AlaskaJon
I thought that could have been it too, but putting it into 4x4 wouldn't fix that problem would it?
Old Nov 8, 2018 | 12:11 PM
Changes the load on the bearing. So, different or no sound isn't a surprise.
