Rebuilt 46RE shutters
Old Nov 12, 2018 | 03:55 PM
82ndVet's Avatar
82ndVet
Default Rebuilt 46RE shutters
I rebuilt my sons 46re and replaced the TQ, cooler, Kolene steels, Alto red eagle clutches, new reverse drum, new piston support, new internal electronics, and installed the trans Jr shift kit. Went for a test drive and there's a bad vibration/ shutter between 1500-2000 RPMs. This only occurs when cruising at a steady speed, slight acceleration, and on the highway at 65-75 MPH. It does it whether the OD is on or off, shifts through the gears nicely with on issues. Any ideas?
Old Nov 12, 2018 | 04:03 PM
What engine? If you have the 3.9, 5.2, or 5.9, what did you do with the crank sensor when you swapped the trans in/out?
Old Nov 12, 2018 | 05:52 PM
82ndVet's Avatar
82ndVet
5.9, I didn't touch the crank sensor. I left it in place when I removed the trans.
Old Nov 13, 2018 | 09:38 AM
I'd be having a look at that then. Your stutter might be a miss..... The crank sensor is a frequent victim of trans swaps.....
