06 ram electonic 4wd.
Old Dec 7, 2018 | 09:37 PM
2belly's Avatar
2belly
Default 06 ram electonic 4wd.
My ram is not engaging in 44wd..I changed the transfer case motor and new selector switch.if I rotate the front axles by hand off the ground the actuator kicks in and lights up dash light,but if I turn switch I get no flashing light or anything.I do have power going to the switch from the key on position...help.please.
Old Dec 9, 2018 | 05:18 PM
3rdgens4sell's Avatar
3rdgens4sell
Have you tried having the tcase shift motor out but plugged in and testing if it works? Is power getting to the shift motor? You say it engages when you spin the front with it jacked up, have you tried engaging 4wd while driving instead of at a stop?
Old Dec 9, 2018 | 07:15 PM
2belly's Avatar
2belly
T case motor is brand new out of the box.,i know that don't mean it works but..I will give a try..thanks.
Old Dec 11, 2018 | 12:41 PM
dodgetruck2's Avatar
dodgetruck2
do you have an abs light on? my 04 wouldn't shift when the abs light came on
Old Dec 12, 2018 | 08:49 AM
2belly's Avatar
2belly
yes it's on,replaced abs pump with a used one now I have to have dealer put my vin in the and module for it to read it.
