Shutter while driving
Old Dec 7, 2018 | 10:27 PM
Dieseldaddy1981's Avatar
Dieseldaddy1981
Default Shutter while driving
I have a 2005 1500 with the 4.7. When accelerating from a stop, it shutters for a second, then it’s fine. The worst issue is driving down the highway. It is shuttering and almost feels like I am riding with no suspension. It is an intermittent issue, but is very frequent. If I stomp on it, or let off the gas, it goes away for a little bit. I was thinking it was the torque converter shutters, so I bought a new one and installed it. It didn’t change anything. Anyone else have any ideas?
Old Dec 9, 2018 | 05:12 PM
3rdgens4sell's Avatar
3rdgens4sell
Have you tried driving the speed it shutters in a different gear? Is it rpm related? Is it engine related or drive train. With what you have said i would think it could be any of the following; coil pack arcing, fuel injector or pressure, drive shaft u joints, center support bearing, drive shaft splines. It could be anything but those are things i would start checking first.
Old Dec 9, 2018 | 08:36 PM
Dieseldaddy1981
i have not tried different gears. I know it does it mainly when I and between 65 and 75. If I let off the gas, it will stop until I accelerate again. It also stops if I mash it. It has not thrown any codes, but the check engine light did come on tonight. I am going to hook it up to the reader in the morning and see if I can pull a fault code.
Old Dec 10, 2018 | 06:12 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I bet it's a misfire. At that speed you are in OD which directly connects the engine and transmission and you will feel misfires lol
Old Dec 10, 2018 | 07:01 AM
Dieseldaddy1981
Thanks mopar fanatic. I was starting to think the same thing myself. I am going to scan it here in a bit, will keep y’all updated.
Old Dec 10, 2018 | 12:08 PM
MoparFanatic21
Please do as it helps readers and future members.
Old Dec 10, 2018 | 12:57 PM
SnowBeast428's Avatar
SnowBeast428
Sounds like a misfire. Check your codes and plugs as I have a v6 4L sohc explorer sport that's the same way in terms of symptoms and it has 2x engine to lean codes and 1x cylinder 3 misfire.
Old Dec 11, 2018 | 07:42 AM
Dieseldaddy1981
It pulled the P0300 code. Multiple misfires. Now I just have to figure out which one of the 15 things that causes it to happen it is.
Old Dec 11, 2018 | 07:45 AM
SnowBeast428
Well the basics are fuel and sparkplugs ajd compression. Usually it's fuel related however in my experience.
