2004 ram 1500
Old Jan 10, 2019 | 06:44 PM
Hotrod1's Avatar
Hotrod1
Angry 2004 ram 1500
Giving me a code with the key trick but the code is A-4 can’t find any info.
Old Jan 10, 2019 | 08:01 PM
Perhaps describing the problem would help us help you.
Old Jan 10, 2019 | 09:10 PM
primem's Avatar
primem
odb II vehicles can't flash out codes...you need a scan tool.
Old Jan 11, 2019 | 06:00 PM
Hotrod1's Avatar
Hotrod1
Transmission changed but does same as last thinking tcu. Got a reader today showing codes. P0732,p1790
Old Jan 11, 2019 | 06:43 PM
Both codes relate to gear ratio/shifting problem. The 1790 will set right after the 0732 as a matter of course. It's telling you that second gear ratio is incorrect. If it's doing this on a second trans, yeah, if there is a separate TCM, I would be lookin' real hard at it.
Old Jan 11, 2019 | 07:56 PM
Hotrod1's Avatar
Hotrod1
Thanx.
