5.7 cam upgrade also 6.1 springs and rods
Old Jan 14, 2019 | 02:27 PM
justin0943's Avatar
justin0943
Default 5.7 cam upgrade also 6.1 springs and rods
Little confused on doing the 6.1 spring some say just for exhaust and change all push rods some say change them all, the cam I'm getting is a howards 264/268 cam from summit racing
Old Jan 15, 2019 | 10:43 AM
What year is your truck? Manufacturer says new valve springs are required. (probably due to more lift than the stock springs are designed for.) A link to the cam in question would be good.
Old Jan 15, 2019 | 11:00 AM
justin0943's Avatar
justin0943
this is the cam
https://www.summitracing.com/parts/hrs-786845-14/make/dodge my truck is an 02 but I put an 04 5.7 in it.been reading more about the spring they say to replace all with 6.1 exhaust spring
Old Jan 15, 2019 | 11:30 AM
Huh, now on the summit page, the only 'suggested part' is the timing set...... Think I would verify what max lift is on the stock springs.... Might be a good idea to have a chat with Summit, (or Howards) to verify the information.
Old Jan 15, 2019 | 12:13 PM
justin0943's Avatar
justin0943
okay will do probably, been doing more research and they all are saying to use 16 6.1 exhaust spring and 8 intake rods and 8 exhaust rods
Old Jan 15, 2019 | 04:07 PM
3rdgens4sell's Avatar
3rdgens4sell
Ive done some research on cams for the 5.7. Lots of info on the lx forum. From what ive read and if i remember correctly the 6.1 exhaust spring has the same assembled height as he 5.7 intake and exhaust springs. The 6.1 intake spring is .1 inch more height. The pushrods are used from the 6.1 because the base circle on the cam is ground from a 6.1 core. The 6.1 cam has a .030 smaller base circle. Some people have there heads milled instead of swapping push rods. Not sure if im allowed to link to the LX forum but there is tons more cam swap info on their site. Are you doing any custom tuning on your set up? Any other mods?
Old Jan 15, 2019 | 04:48 PM
justin0943's Avatar
justin0943
already got true dual exhaust x pipe and mid headers as for tune already got my rpm set around 625 when warm and 700 or so when ac on I hated when it was at 500 the truck when stopping sometime shut off but ever since I did the no problem.im not doing the 6.1 cam it's a Howard 264/268 cam on summit racing website
Old Jan 27, 2019 | 09:51 PM
justin0943's Avatar
justin0943
Update went ahead an got the cam also got 16 6.1 exhaust springs,6.1 push rods and all new gaskets and head bolts. Ps jegs had this cam $100 cheaper
Old Jan 27, 2019 | 10:12 PM
16 exhaust springs?? Gonna use those on the intake as well??
Old Jan 28, 2019 | 10:58 AM
justin0943's Avatar
justin0943
yes because 6.1 Intake are taller but the 6.1 exhaust spring are the same size as 5.7 intake and exhaust spring.
