Brake Lights Died
Old Feb 7, 2019 | 10:26 AM
THRobinson's Avatar
THRobinson
Default Brake Lights Died
We had some really cold weather last week, cold enough to trigger my engine light actually, though ODBII shows 0 errors, When it warmed up the light went off.
Also, the brake lights quit. Middle/3rd light works on the cab, just the 2 on the box are now dead. Bulbs seem fine.
Would this be a switch? or I read somewhere the front control module? which I also read some say just swap it, and some say Dodge has to do it because of programming?Hoping a part I can get used and do myself.
any ideas how/where to start testing?
Old Feb 7, 2019 | 11:09 AM
jrsick's Avatar
jrsick
I'd recommend testing your brake lamp switch first. You'll see it contacting the brake pedal, just trace the pedal up.
Disconnect the switch harness: Turn the release lever then remove the harness.
Remove the switch from its mount: Push on the brake pedal then rotate the switch counterclockwise then pull it out of the bracket from the rear.
You'll see six pins. You should have continuity between pins 1 and 2 with plunger extended. You should have continuity between 3 and 4, and, between 5 and 6 with plunger retracted. If it fails any of the continuity checks then switch is bad and needs to be replaced.
Old Feb 7, 2019 | 11:13 AM
THRobinson's Avatar
THRobinson
Dumb question but, switch or FCM... why does the 3rd brake light still work? would have thought if one went out, they'd all go out. 2 switches? or 1 switch 2 outputs?
Old Feb 7, 2019 | 03:25 PM
The rear lights also go thru the multi-function (turn signals) switch. The third eye does not. Do your turn signals work?
Old Feb 7, 2019 | 03:29 PM
THRobinson's Avatar
THRobinson
Yes... and no....
Other issue I have is that the front/right turn signal keeps blowing bulbs. Good not cheap ones too. Not sure if a power surge deal, bad wire, bad socket. In Canada and well, too cold to figure it out right now.
But, with working bulbs, they (last I checked) are working.
Old Feb 7, 2019 | 03:41 PM
Check the grounds..... (when it warms up. )
Are you getting any 'lamp out' messages on the dash?
Old Feb 7, 2019 | 03:44 PM
THRobinson's Avatar
THRobinson
Ya, came on when the front/left turn signal blew again, which is still out. I'm outside for working on the truck, and last week was almost -30 degrees and a foot of snow so, gathering info now and first dry day I'll be out doing stuff.
Old Feb 10, 2019 | 10:49 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The brake lights control panel are known to go bad. (The board the lights connect to) I would have someone press the brake and (with a test light) see if you are getting power back to the lights.
