3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
say I have a 08 and I took it to dodge to see what’s going on so they told me that my tipm was bad and actuator was bad and the L/f wheel speed sensor was shot well I let them replace the tipm and they said the reprogram it cause if they didn’t the truck would of never start. So the I bought a new wheel speed sensor and actuator I put all that in myself well my 4x4 is still flashing I can hear the back making noise but nothing from the front for noise put test light on wires and out of the four one light up but then put meter on and all four had power I am lost don’t know what to do
Can you hear the motor kicking in? Take the whole actuator assembly off the front axle. Once it's off get someone to engage 4wd see if the fork moves. If it does then inspect the collar and everything.
