oil pressure gauge
Old Feb 25, 2019 | 11:57 AM
BigHoss37's Avatar
BigHoss37
Default oil pressure gauge
Hey so I have a 2008 ram 2500 and the other day I felt the guage wasn't reading right and now today it didn't even move and yes I do have oil in the truck if you were wondering. But what would cause this to happen, we have had a lot of snow and cold would that be a issue? thanks
Old Feb 25, 2019 | 12:41 PM
Sender is probably bad, or the pump. You can put a mechanical gauge on it to verify.
Old Feb 26, 2019 | 06:59 AM
jrsick's Avatar
jrsick
I assume you have a 5.7 gas engine.
Any unusual engine noises? Any reason to think there might be a blockage in your oil filter? What does oil pressure gauge do on start-up?
If all else is normal, what I would do is get a loaner oil pressure gauge from auto parts store. Remove the oil sender (above the oil filter), and check for at least 4psi at warm idle and 25 psi at 3000 rpm.
If that's all good, replace the sender.
Old Feb 26, 2019 | 11:45 AM
BigHoss37's Avatar
BigHoss37
thanks guys so yes it is the 5.7 sorry should have added that. so one time it moved about a 1/4 of the way up and then the next it didn't move at all, now today it was working back to normal again. does this help at all or just confuse the situation more thanks again
That just points even more toward a failing sensor.
Old Feb 26, 2019 | 12:25 PM
jrsick's Avatar
jrsick
Yep, I'd say just replace the sender. You'll need a 1 1/8 deep socket.
